More junkbox mayhem - an 0-6-0
Plow arrived today, so I cut it up.
(http://i1082.photobucket.com/albums/j371/AlleghenyValley/P3070020.jpg)
And then used the chunks to reinforce it where the pilot would bear.
(http://i1082.photobucket.com/albums/j371/AlleghenyValley/P3070021.jpg)
While the glue was drying on that I cut the tender shell for the charging jack and on/off switch box.
(http://i1082.photobucket.com/albums/j371/AlleghenyValley/P3070022.jpg)
With the ‘air tank’ cover in place.
(http://i1082.photobucket.com/albums/j371/AlleghenyValley/P3070024.jpg)
Plow attached to the chassis, boiler mocked up… I think this might just work!
(http://i1082.photobucket.com/albums/j371/AlleghenyValley/P3080025.jpg)
Looks great so far. You will like the critter control. Im using the simple on my stuff and love it. Very easy to work with.
Somebody is probably going to say “about flipping time!”, but I finally wired the tender for this thing today! Aaand… the 3800 mah battery packs are just a smidge too big to fit the way I wanted, so I’m going to have to rearrange things, or make the tender 3/8" taller.
I wired it so I could switch the batteries to parallel to charge, and then series to run using a simple dpdt switch. I also wired in another dpdt between the critter control and the motor leads, so I can change it over to track power if needed (IF I ever get the pickups installed) Del’s Basic Critter Control was a fairly easy installation. The only un-positive comment I have about it is wiring 3-1 and 5-3 on the board to rotary switch is a little counter-intuitive since you also wire 2-2 and 4-4. It’s just one of those “hey dummy, pay attention!” things.
The batteries are getting a conditioning cycle before I try hooking up the loco to see if the wheels go 'round. If all goes well, I guess I gotta fabricate a drawbar and finish the loco. — at which point we won’t have snow?
