So in my quest to make some more interesting and varied 1:29 rolling stock, I found out that REA/Aristo used to make an outside-braced reefer. Cool! I found someone who had one in stock, and ordered it. Yikes! It’s not a good model. Looks like it was made from very worn molds, detail is fuzzy. But worst of all is this:
A big nasty molded in diamond, leftover from this boxcar being labeled for Railway Express Agency. Ugh! Looks terrible. So what to do? I decided to try to cut it off. I used a dremel with a router collar to chew off a lot of it, after using a razor saw to cut a clean line along the braces. Then lots of filing bondo glazing putty, using needle files to cut plank lines, and voila:
Yuck. I’m sure many of you are saying it would be easier to just build the thing from scratch. So is this redeemable? I’m thinking of roughing up the styrene “boards” before repainting, and then maybe some of this mess will pass for weathering. Put a big logo there, might get away with it. Alternatively I thought of making a wooden sign and attaching it where the molded on diamond was–a square with some ad on it maybe. i also thought of replacing the reefer door with a conventional boxcar door, building a wooden door, and leaving it open to partially cover the mess. But then I’d have to leave it open on both sides Any suggestions on how to make a silk purse out of this sow’s ear?
