GARTENBAHNprofi ran an earlier test - prior to the recall by the manufacturer. The latest issue of GBp has an updated test/review.
Since this a European engine it probably is of limited interest, however here goes.
They ran the tests in late July/early August while the temperatures flucuated between 20ºC and the high 30s. Most of the time at around 30ºC (86ºF). Simultaneous to testing the E10 they were also running LGB’s BR101 and PIKO’s E 94.
One test track with R3 curves (4ft rad) and 1.5% grades, the other with 3.5% grades.
The recall was issued on account of insufficient tractive effort (5.5N), the improved version produces just a shade under 10N. The previous 4 traction tires have been reduced to 2. All wheels are now used for power pick-up, in total there are now 12 power pick-up points.
So far the good news!
The not-so good news: the power consumption of the motors with 3 LGB Bim cars was 2.8amp i.e. a 3A decoder will not be sufficient. Typical symptoms: the axles tend to slip at the culmination points of grades and the decoder’s Back-EMF function is unable to compensate and shuts down. With a 6A decoder it will take longer before the condition manifests (max 25 minutes).
The motors run very hot.
Conclusion: OK for indoor layouts and outdoor layouts with mild grades(1.5% max), larger than 3A decoder required if extended running is a must.
:-p
