@ Craig, John, et All. I too was gifted the cheep Micro-mark saw. Oh Well, The rip fence is basically useless, and the crosscut is only slightly better.
Set out to fix the shortcomings and here are two of the fixes
The cross cut I made from wood, Set at 90 and with the long tongue stays square. The rip fence I milled.
Fence is of 1/2" bar stock. I used the tightener from the original. Fits on either side of the blade. Its adjusted to be parallel to the blade.
99% of all that I cut is Square cuts. The fence alone has tripled my using pleasure. I can get repeatable cuts with consistent size. I also built a “Mini Sled” that cuts 45’s. I have a foot switch that turns it on-off, so I don’t have to mess with the power button. And I mounted it to a board that slips over the “Pull out Bread board” on my work bench, so it is well secured and doesn’t move about.
My single biggest complaint… Underpowered! But if you stay to under 1/4" stock NOT an issue. For 1/4" stuff I have a dedicated old 10" Craftsman that I have re-worked for the small stuff and ripping down to scale sizes.
Now I would like a Proxon, don’t get me wrong, But this little saw has given me GREAT value for the buck, and the Cheep Basta%d in me just can’t grasp spending 1/4 the price of my Delta cabinet saw on a little tabletop. Especially with the old Craftsman set for little stuff.
