Somebody 'splain this to me:
For years, I’ve run Madam Mallet on 19.2v NIMH batteries. She’s quite happy to run that way even today.
Last spring, while I still had the new job, I bought a Tenergy Li-Ion 14.8v 5200mAh pack and a charger to go with it. I put the connectors on, charged the pack. All seems fine, but Madam Mallet does not see anything coming out of it. The little red light on the old TE receiver comes on, and promptly goes out. “Hmm. I thought the old TE would work at 14.8.”
Well, now, both the old NiMH chargers have gone to pot and will only give me 20 hour trickle-charge rate, so I decided to get to the bottom of the Li-Ion pack problem.
So here’s what I did. I measured the unloaded battery at 16v. Looks Ok. I connected it up to the loco and nothing. Measures 1v. “Hmm. Wonder how much current I’m drawing.”
I turned my meter to 10A scale thinking I must be drawing lots of amps and shutting the thing down. I used clip leads to connect the black wire of the battery to the black wire of the loco, and connected the red wire of the battery to the red wire of the loco and read 380mA and the lights and sound turned on! If I use the remote to give her some juice, she’s moving at about 1 amp (no cars). I don’t go far 'cause all the gory guts are laying beside her connected by clip leads.
“Perhaps my connector is bad.” That wouldn’t be a BIG surprise. I unhooked the clip leads and connected the battery back up. Nada, as anticipated. I measured the battery voltage ahead of the connector, 1v. (This is now the battery side of the connector.)
I unplugged the connectors and hooked it back up with clip leads and 10A meter. 380mA. Loco is on. Even moves when I tell it to. So I took the meter out of the circuit and just used clip leads. Big sparks when I went to clip red to red, and no life. I put the meter back in, and it says 380mA and the sound and lights come on.
Do you think maybe: The old TE draws such an inrush of amps that the little board shuts the battery down and the shunt in my 10A meter reduces it enough to work?
Baffled, mystified, and moderately grumpy over this.
