While we still await delivery of our kit, the back shop created the “one horse-powered" motive power that will be used to draw the California Experience from town to town, but also power the dynamo and pump for the hot tub, and the PTO, and anything else we come up with that will fit on the rail car.
The basis of the motive power is an old truck of unknown origin. A 5” long piece of ¾” wide brass serves as the platform to hold the dynamo and pump. The brass was purchased in bulk when a hobby shop went out of business back when I was getting into the hobby in 1998 and its assets were auctioned off. Scrap pieces of aluminum ½” “L” were CA’ed to the brass to cradle the motors and provide a point of attachment to pull the rail car. The motors are Mabuchi (6 volt?) and came in a “grab bag” from Goldmine Electronics (surplus) many years ago. I never thought I would use them.
(http://www.largescalecentral.com/public/album_photo/95/ce/01/1cbc8_b0ea.JPG?c=2d3a)
The axles have fuel line/vacuum hose pressed over them for a strong friction fit. The rubber provides good friction both for the drive belts (rubber bands) and the hamster wheel. Vacuum hose can also be slipped over the ends of the shafts to provide PTO to operate other amenities on the rail car once the assembly is hauled aboard. Plastruct (purchased in bulk at the same auction) slips over the motor shaft providing a strong friction fit. Various sizes of Plastruct/fuel line can be used to adjust the drive ratio once up and running.
The truck is actually run upside down, but the motors are small enough and don’t hang below the tires such that it can run with either side up.
(http://www.largescalecentral.com/public/album_photo/91/ce/01/1cbc4_f6eb.JPG?c=e895)
Then I had to train (PI) the horse to walk inside the wheel without losing his balance. The hooves were ground down and special neodymium “horse shoes” applied. (The real trick is getting the second magnet on the adjoining hoof as it wants to instantly jump to the first magnet.) Also, the magnets had to be positioned such that they ride against the hamster wheel when the horse is standing within.
(http://www.largescalecentral.com/public/album_photo/99/ce/01/1cbcc_4317.JPG?c=3e6d)
Magnets mounted to the motor/truck then keep the horse in place as the hamster wheel spins/slides under his feet. The attraction between the hooves and truck magnets actually help hold the hamster wheel to the truck, as it turns, keeping it from popping off.
(http://www.largescalecentral.com/public/album_photo/9d/ce/01/1cbd0_4d77.JPG?c=266c)
A future iteration may have the horse actually gallop within the wheel. The AristoCraft horses are hollow and the head comes off for inside access. A Kadee spring fits within each leg and can be glued in place. The legs can then be cut with a sharp X-acto and the spring will then hold it in place and let it articulate in all directions. The fuel line hoses on the axles can have small holes drilled into them fitted with magnets. As the axles rotate they will attract/repel the legs making the horse gallop.
But this would require that the horse be suspended just above the hamster wheel because the legs would no longer support it. “Someone” standing next to the horse with a hand on it, or some form of harness/whip/dangling carrot could do the trick. However, this would preclude the horse pulling the rail car. (A second galloping horse could be a future project for when the wheel is hauled up onto the rail car.)
(http://www.largescalecentral.com/public/album_photo/a1/ce/01/1cbd4_963d.JPG?c=68eb)
