OK, as mentioned, I had to take a break from the action, but, we had progress in fits and starts…
Oldest Son and I continued converting beverage cans into corrugated roofing. He discovered the best way to get rid of the curl was to take the “4x8” sheets into the yard and batter it with a mallet. Of course, running it through the crimper (seen below on top of the structure) put a curve into it, anyway:
I glued it to the roof with TiteBond III and weighted all the sheets in place. I was surprised how easy it was to make corrugated metal in general. You can even run the sheets through the crimper multiple times. I will have to find better glues or better ways to straighten it.
The project sort of went fallow after that. My hours, school projects, and the unexpected loss of our beloved cattle dog “Mr. Otto” took the wind out of our collective sails. Still, Oldest Son completed boarding up the wall by interpreting “take some scraps and glue them above and below the window” as “take whole craft sticks, board up the windows, and wait for Dad so we can Dremel it all out.” Youngest Daughter, meanwhile, used Sculptamold to make some pastries:
They look good enough to make any PLAYMOBIL dude happy! Oldest Daughter had a school project, but she painted the chimney. Interestingly, she started by dry brushing, then experimented with a Q-tip, before migrating on to her index finger:
If the technique isn’t dangerous, let 'em try it!
Today was supposed to be the big catch-up day. Naturally, the weather was gorgeous, so I lost the use of Oldest Daughter when she and her friends headed off to the beach. Oldest Son, however, decided to lend-to, and lend-to he did as we sawed, Dremel-ed, glued, and clamped away the day. First, of course we prepared the work area, which, naturally, required bringing the Triple O to life:
Next, we had to figure out how to cut out those windows. To be fair, we had use the plan-over-and-cut-out-later technique before, and it works fine. The difficulty here was that the foam walls are much thicker, so it was tricky to get in there and cut it all out:
I had to finish this portion of the job, as the vibration proved uncomfortable for him. From then on, it was a really neat dance as we passed saw, mitre box, glue, and clamps back and forth to finish both the exterior and his service counter (below):
Kid-zilla joined us, too. I am pretty sure his efforts are on the final product somewhere!
We did the window frames and some trim pieces, and both exercises showed the limit of craftsticks, at least a limit in my hands. As another person mentioned, they are not really uniform, making long pieces of trim difficult. Had I taken this into consideration at the start, I would have adjusted the structure’s size as well as the windows’ dimensions. Hopefully, paint, possibly a bit of sanding filler, help smooth things out a bit. Also, my miscommunication about how I wanted to do the windows meant I had to use oversized window trim. Things worked out better for the doors, which are painted hotel room keys. The structure as it stood at dinner time looks like this:
Tomorrow, we will try to add some trim to the roof, too, and I plan to cut up some shattered epee blades to cover up that seam where the roof takes its downward turn. Clearly, we have to do some fitting and fiddling to get the chimney to fit a bit better. The plan is to be done with the glue by tomorrow evening. We shall see…
While I like to keep these posts on topic, I wanted to close tonight with a little tribute to my “fur buddy” Mr. Otto. He was never far as the Triple O took shape, and his pawprint is in the retaining wall to commemorate his canine involvement, so I figured he has a place on this thread. The photo was taken late December on a family hike up Mokapu’u:
The Triple O is a bit quieter now…
