Korm Kormsen said:
if you can, (spacewise) it might be a good idea, to give the whole thing some depth.
where i used inserted pics or drawings in windows, i put them one inch behind the window openings.
that gave me enough space, to cover the backside of the wall with alu foil and hang a bulb or two to lighten up the pics.
Yes, that is the plan. Tonight’s project will be creating the framing to hang the foam on and install some RGB LED light strips to wash over the photos in any color I’m in the mood for (https://largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-sealed.gif). I’m planning on 1.5" of open space behind the foam. I might change to a 3/4" foam for a lot of the face so the window openings are not so hard to cut.
The drawing goes on the large format printer tomorrow than I can figure out how I’m actually going to do this!
