Decided to mix up the 1:2 version for spray. It’s a really convoluted formula: First split India Ink and Alcohol 50/50. I used a half ounce of each measured out as 12 x .25Tsp because that’s what I had on hand that I could use. Next this one once of mix mix gets further cut with 8 ounces of pure alcohol for a resulting batch of 9 ounces. That gets you to where I was when I started color tests. For my final cut I took that 9 ounces and added 18 ounces of pure alcohol to get my spray dilution.
I have a nice Earlex HVLP Spray system I bought for work. Borrowed it for the weekend to spray my Mik project. It was a beautiful day to spray outdoors. A little gusty, but blowing away from the house and cars. Here is the gun; turbine on the ground in the background…
I should have quit at this point; the shade is about perfect, but there were spots that looked like they had been missed, so I kept spraying. Turns out it was glue protecting the grain…
But I kept on spraying trying to even it out. Ended up quite a bit darker than I wanted, but I don’t hate enough to try and lighten it…
A comparison of what I got Vs the natural color on similar species of wood. The cedar color spots are glue protecting the wood fibers. Directions say to sand it off, but I don’t want a sanded look so I decided to not worry about it. Could always go over it with some paint if it bothers me…
Then I spent the afternoon cleaning up the mess from milling lumber. I photographed and measured my pile for evidence, but I’ll save that for a who’s is bigger thread.
@Doug - Did you spy it?
