The crew was about to cut wood…‘No!’ said the top guy, “We will be penalized if we start early.” Boy that logic does not compute the crew thought. but when we build off of napkins, there is no logic - sometimes ![]()
This year will be a cabin in the woods. This will be smaller than the 800 sq ft requirement, but as the instructions stated…“If you build it smaller then 800 SqFt. ALL THE ROOF MUST BE COVERED WITH THE PANELS. You may use the extra panels as you see fit.” so the roof WILL be covered and the extras will be used as I see fit (hopefully fitting very well).
