Howdy!
Looking over the various websites, and easpcially EBAY, beginners find out early that there’s a LOT of metal wheels being sold out there.
From what I’ve seen there are definite advantages to going with metal rather than plastic; if nothing else, the track crud argument hits home with me, especially after the first time I cleaned up wheels on used rolling stock!
Stock Bachmann metal wheels on some of the stuff are downright bizarre; a plastic wheel with a metal tire. It seems logical, but they’ve already lost my respect; I have a few of Bachmann wheel sets here that don’t run true. There’s VERY obvious wobble as they rotate! These winners turned up on the combine and observation cars that came with my Royal Blue set (apparently of 2nd generation locomotive vintage).
Is there any way to true these beasts, or is replacement unavoidable?
On EBAY I’m seeing an awful LOT of sellers offering metal wheels using ball bearing centers. The claim is that the bearings reduce rolling resistance (a quite logical assumption, IMHO).
Is the amount of friction reduction you gain significant? Like, for a long, maximum load train without these wheels, will a change to ball bearings allow you to tack on an extra car or two?
I can see the improvement of these things on curves; the independently rolling wheels will provide a differential action that might significantly reduce rolling resistance.
Next question…
The coaches have internal lighting, provided by a 9 volt transistor radio battery. I haven’t measured the current drain personally as yet, but the grain of wheat bulbs used just HAVE to REALLY suck current… and those batteries are no longer cheap (Radio Shack, you’ve stabbed me in the back!). The obvious solution is to upgrade the illumination system in the cars.
Obviously… LEDs are the way to go here; they’ll probably reduce current drain by 80%, as well as giving a longer life than bulbs. But that idea inspires going one step further.
The battery compartment on the cars is perfect for housing an LM-317 voltage regulator chip, fed by track pickups. I don’t doubt that others have taken that approach.
Checking the spec sheet on the chip, the low voltage drop-out voltage on the output side is 1.2 volts. If you set up the LED string with a current limiting resistor for 1.2 volts, the lights should go on at full intensity at very low speeds. If a single, small NiCad cell is also floated across the regulator output (a 1.2 volt device), the lights will stay on during full stops, and the cell will be recharged whenever the track DC is on.
What all of this has to do with wheels is simple… adding pickup brushes to trucks is the obvious move.
The cost of commercially made pickups is a bit scary, besides the fact that they look like they add a VERY significant amount of drag and rolling resistance.
I’m thinking a small chunk of PC board added to the truck that carries small brass sliding contacts that ride the inside of the wheels.
Can it be done with less friction / rolling resistance than commercially made wheel brushes?
Thanks in advance for the advice, Guys!
Mr. T.
