So I’m about to bite the bullet and start building a brass model for the first time, and I’m wondering if I should use different types of solder (melting points) so that each sub assembly can be separately built up with a higher temp solder, and then joined to the main structure with a lower temp solder. I’ve heard the term ‘silver soldering’ for live steamers, but what type of solder is used for that?
Right now, I’ve got two types of solder on hand; resin core for electrical projects, and a thicker solid solder that I used for replumbing a part of the house. I’m guessing that these two have different melting points?
Anyone got some help to lead me in the right direction? I recall seeing a couple of brass model projects over the years here…
