Hi all, In the figures forum I posted pictures showing Dr. Henery Hurts taking a smoke break. Brian wanted to see pictures of the entire building so here it is. This is one in a series of “flats” that fit along the outside wall of my train shed. McCormick-Saeltzer was a general store that operated in our town from about 1880’s to the 1950’s. They didn’t really have a direct rail connection but I took a little artistic license and added them on line at the back of their building.
As you can see they are strictly background scenery to break up the shed wall. The material is foam and the primary tool is soldering iron as per Yogi Wallace.
In this view you can see the “hollow shell” of the foam construction the 2X4 base with the brick pieces are just to give the project a little heft so it won’t be affected by the wind.
This roofing method I discovered pretty much by accident. It is a ground cork impregnated mastic tape used for insulating pipes. It is self glued to a clear Acrylic under sheet then sprinkled with fine sand. It passes as a fairly creditable mineral felt rolled roofing.
