Maximum grades
I need your advice,
I have a two level yard. I can run trains at a constant 3% grade from one end to the other (the bottom loop is under a tree.)
or I could run trains down hill at a 6% + grade for 10 feet , but then run at a 1% grade on both levels with a short 8 feet run of 41/2% to 5% grade.
Otherwise my track will be elevated 6"+ . She who must be obeyed is not in favor of track floating in her garden (existing). I would also have to construct two removable bridges to walk thru an existing trellis/gate.
This is a logging railroad, continous loop, short trains, one direction,R/C battery powered. I am looking at Bachmann Shay, Heisler to pull 5-6 , 40’ cars. Also LGB 040 #2 with 3-4 car starter set. My intention is to run trains for short periods of time. I know it is not ideal but I call stay more traditional down stair in winter. Your suggestions or comments.
SteveZ
A 6% grade is prototypical for geared engines such as the Shay. Go for it. The main thing is to get track down on the ground (or up on stilts if that is your wish) and run trains. Then you can start fine tuning it. No one ever gets it perfect the first time, just as no railroad is ever finished until it is abandoned.
Don’t forget to keep us up to date with pics!
SteveF
SteveZ,
Welcome aboard! Not sure why you posted in the “Website” area, but that’s not really important. I think your SWMBO will be amazed at the number of people that pay attention to her garden because of your trains running through it.
The ideas of the heavy grade justifies the reason for the geared equipment. It all makes sense and will give you a real feeling of satisfaction watching the engine work the hill. Like others said, I really would like to see pictures.
Sorry, for posting in this section, I’ll repost in tracks.
stevez
