During the Invasion, some of us had an Ops Session on Doug Matheson’s Layout. Bruce got assigned the quarry train and it produced quite a unique switching puzzle. At least unique to me.
The instruction read-
At the quarry, exchange the cars for the 5 cars that are there, then push those cars up the hill – there is less chance of derailment if the light flats are first with the heavier gons against the loco.
The track plan in the quarry is a siding at the bottom of a steep hill that holds 5 loaded rock hoppers.
Next to the rock siding is a pair of run around sidings, that each track holds 3 cars. The tail of the run around siding is only long enough for the engine.
Instructions state the motive power must always be on the down hill side of the train, when coming down the hill with 5 empties and going back up the hill with the 5 loads.
Bruce worked at it. I got done with my work and went over to help. We couldn’t figure out how to exchange the 5 empties for the 5 loads and keep the engine on the down hill side.
I have no graphic abilities on these confusers, so if someone wants to draw this puzzle up, the help is appreciated.
By the way, we were called to lunch before we completed the puzzle. Doug swears it can be done.
Step 1 - Move 3 empties to one of the two run around sidings (run around track A).
Step 2 - Escape on the other leg of the run around track (run around track B).
Step 3 - Put 3 of the loads on the run around track you escaped on (run around track B).
Step 4 - Grab the other two loads and then pick up the 3 empties you put on the first run around track (run around track A).
Step 5 - Put those empties off of run around track A into the now empty rock siding.
Step 6 - leave the 2 loads coupled to the 3 empties on rock siding.
Step 7 - Pick up other 2 empties off of track lead and put in run around track A.
Step 8 - escape on run around track B pushing loads up to now empty track lead.
Step 9 - Pick up other 2 loads that are in the rock siding with the 3 empties.
Step 10 - Pick up 2 empties on run around track A and put in rock siding with other 3 empties.
Step 11 - Leave 2 load on empty run around track B.
Step 12 - Use run around track A to get down hill of those last 2 loads.
Step 13 - Shove 2 loads up to couple with 3 loads on the track lead and shove all 5 up the hill.
Seems simple enough, right Bruce?
