For DCC Experts: I just finished installing a customer-provided Massoth XLS older version sound decoder into his LGB Mogul locomotive. Everything is working fine in DCC mode but when powering the loco in DC/Analog power, the headlight pulses on-off. There’s also a noticable low hum noise in the speaker when applying DC power to the decoder. Connected to the decoder is the standard LGB Mogul’s smoke unit, the headlight, a Massoth hall sensor/chuff pulse generator, a Massoth Sound Function Trigger/PCB, and a Massoth volume control “pot.” The Mogul owner plans to operate this Mogul on his MTS III layout, but also wants to be able to operate it in DC/Analog power, thus the sound function trigger installed for activating the whistle and bell with track magnets.
Using either 14 or 28 speed steps causes the headlight/sound humming issue. This older XLS decoder is finicky…I’ve had to reset it three times when it stopped working during various test runs of the loco, either on my programming track with roller wheels, or on my small 15 x 6 foot indoor layout. I use a Piko Central Station for my test bed/programming track, and a Massoth DCC Central Station/Power Supply for my indoor layout and my new garden railway I’m installing with over 350 feet of track.
Any CV adjustments suggested to eliminate this light pulsing/flickering would be appreciated!
Thanks
Tom
