Been working on my mason bogie project, using an LGB Spreewalt drive, Lionel gold rush engine cab, boiler and detail parts and a Eztech tender body. Just completed the chop and shortening of the tender part and added rivets that I got from Mirce in Russia @ nsmodelers.rs which are designed to be used on model air planes. They are of the fairly flat variety and looked pretty good until I sprayed a coat of paint on them and a lot of the detail was lost so I added a drop of gel superglue to the top of each rivet for some beef. Am very happy with the results, installing the rivets consists of removing them from a sheet with scotch tape and pressing into place then removing the tape, pretty simple and while adding the superglue sounds time consuming it really wasn’t and added about 10 minutes to the project. Was easy to make straight lines and with them already evenly spaced made for a simple job for shaky hands.
