Over on one of those other forums, I found some neat replacements for the jewels used in marker lights.
You can get these from Mouser Electronics for under 30 cents each. = http://www.mouser.com/search/ProductDetail.aspx?R=CLB300RTPvirtualkey59300000virtualkey593-3000R - you’ll probably spend more in postage than on the product. They come in red, green, yellow, amber, blue, and clear. http://www.mouser.com/search/Refine.aspx?Ne=1447464+254016&Ntt=clb300&Ntx=mode%2bmatchall&Mkw=clb300&N=1323038&Ntk=Mouser_Wildcards Check out the data sheet and you can see it’s a lens with a tube attached - I just used my razor saw to cut off the lens part and glued them in place. In this case, I’m using them with 1.5volt lights - and they look a whole lot better than those old jewels.
