Or, fixing it. Those of you that were here for TrainOps knew that I had a frost heave problem in the tunnel area by Pearce. When this track was built 6 years ago, it had a nice < 2% grade. Some spot measurements showed it rolling from almost level to 5% in areas. Combine that with the curve, and trains had a tough time making it up. Measuring the rise and run, it should be around 1.6%. So, time for some work! I took up all the track from the switch at Pearce, down to the switch for Majestic. I did a bit of re-leveling of the twin arch bridge leading into Majestic, and did a survey for what the next steps are going to be.
