Hey Y’all;
Been making some modifications to Big Hauler train set track - something to which a slight misquote of Hamlet may be applicable, “Though this be method, there is yet madness to it.”
Making some feeder connections from wiring and plugs stripped from Christmas light reels purchased for stripping the LED from. They do make an observable difference on the large loop.
And …
Trying my luck at creating track sections with insulating gaps. Am doing 2 straights and 2 curves.
Reinforced stringers under rails toward one end of piece. Sawed through both rails. Inserted sheet plastic to fill gap. Am adding imitation fishplates to outside of rail to help stabilize it.
Second step is to add headblocks from ties either side of block by cutting out one end of tie each side of gap, adding 6 inch piece of 1/4 by 1/4 basswood, then coming up with some way to mount an appropriately sized double pole, single throw, toggle switch where on a turnout the switchstand would be.
For now, the feeder wires provide power, plug it in for power, unplug to cut power. Kind of a what I’d call a trailer park redneck tech level method, but hey, it works for now
My track is currently at our model train club set up on floor under HO modular layout’s yards. Track is classic oval with cutoff at one end. What I want to do is be able to park a train on either inner our outer track, shut off that track; then turn on other track, and run other train, rinse and repeat as desired.
Theoretically, this will get you to a 10 picture album of the project, and my hairy little “helper”, who knew model trains were a spectator sport, on Flickr https://flic.kr/s/aHsktynbLL
Added a few more photos, closeups of the rail ends and joining details.
