Michael Glavin said:
Devon
You CAN use Li-Po batteries. PCB low voltage is simply a gadget used to help ruin your battery pack and or provide you with a false sense of security. I use Li-Po’s on trains, plains and copters.
And yes there are Li-Po batteries available with PCB’s (slim pickings though) or you can simply use a PCB as an ancillary device or maintain/utilize your batteries correctly and there is no need for a PCB. And there are gadgets available for a couple bucks that plug into the balance pigtail and make noise, flash lights or display voltage telling you when the battery has discharged to the appropriate voltage level, which is long before a battery with a PCB low voltage cut-out takes hold.
That said NiMH will work fine IME, yet you can run these batteries down below safe voltage numbers too, which like other technologies; will eventually contribute to short life cycles. So best case is to monitor your batteries voltage while your running your trains (I alluded to several options above).
Michael
I am not doubting you at all Michael. I just am no battery expert and don’t really want to become one so I rely on guys like you to tell me what I can and can’t do. I have no doubt you can run LiPO. The other R/C guys do it in planes,cars, and boats and we are not reinventing the wheel so I believe it can be done safely. With that said though I don’t want to buck the manufacturer when they say its not set up for Lithium batteries. Now I don’t know why they say that. I trust Tony’s answer. So, could a guy use a Li battery and make it work, probably, but I am not going to be the guy to try. If NiMH works and is recommended by the manufacturer and the retailer then I will go that route. Its just a comfort thing to me.
Now I do have a completely ignorant question for you though. You say to monitor the voltage of any of the batteries I use while running trains. Well how would one do this? I could see it if access were easy and one could stick a volt meter to it and one of my locos I could do this, its a matter of just lifting the coal load. But on my GP/9 there is no easy access to the battery. Hence on board charging jack so I don’t have to remove the battery. So how would/could a person check the batteries? On Li-Ion I just run it til it dies. I mean it goes from running to dead almost instantly (kinda why I like Li batteries). On NiMH I would assume the thing will just become sluggish when it is running out of juice. Is there a better way?
With that said I popped the bonnet on the tank loco and well to my surprise its like a giant cavern in there. I will have no trouble whatsoever fitting everything in there including probably an extra pound of weight. I will be able to make two banks of four cells each in tanks. I am thinking that the ESC and RX will easily fit between the motor and back head. I will put the switches on the underside of the tank. This leaves the entire area in front of the motor for weight right over the axles.
What is the best way to adhere the batteries to plastic, rubber cement/ hot glue? I want to be able to remove them if and when they die so nothing to permanent.
