We were talking the other day about how difficult some locos are to disconnect the engine and tender - especially the ones with lots of ‘stuff’ in the tender.
I recalled seeing magnetic connectors on Aliexpress, so I ordered some. Turned out I had a perfect application - my new live steam loco has a servo in the cab with a long lead to the RX (rc receiver) in the tender. It has to be poked through a small square hole in the front and then plugged in to the RX. Not the quickest and easiest way to uncouple and disconnect the two.
Here’s my new magnetic connector with a bundle of r/c cables.
I clipped an end of one of the cables and soldered it to the new conector, which just happened to have 4 leads, and 3 were the right color.
Then I cut the loco’s cable and soldered the other connector to it.
And that was it. It works, and I can unplug the loco from the tender anytime I want.
They are $2.75 each (male or female) from
https://www.aliexpress.us/item/3256802830203313.html
