I’ve been using the Magic Motorman reverse unit for years. However, it appears finaly to have given up the ghost and they are no longer made. The setup I have is one mainline with a reverse loop on each end. The loops are constant polarity and powered together while the mainline power would switch polarity once the train was within each loop so the train would exit the loop successfully without stoping, jerking or slowing down. The Magic Motorman handles all of this.
The setup can be as complicated as one would like, or as simple as how I use it. The train always enters each loop in the same direction. The switches are spring loaded not electric so the train pushes the points to the correct position upon exiting the loops. The points then spring back to the correct loop entering position.
Does anyone have one of these units they would like to sell? If not, I am looking for another simple alternative anyone can recommend.
I currently also own the Massoth DiMAX Reverse Loop Module but have never used it. It will work in a number of configurations as well as Analog. It appears that it should work in my configuration however, the wiring is very confusing to me as I am not an expert.
Any help is much appreciated. Thanks!
