John,
Sorry for being late to reply to your post, but…here goes.
This is a shot of the right side drivers on my 1-1/2" scale Gene Allen ten wheeler. All of the counterweights on this engine are the same size as cast. The ONLY difference is the thickness of each counterweight…how far they extend beyond the rim and spokes. I believe there are 14 spokes on each wheel.
This is the center driver and the main driver. The weight on this wheel is a little thicker to allow for the weight of the main rod pin and the side rods on the front and rear of this pin. The pin is actually longer than the others because of the added rods. The pin and joint behind the main pin allows the side rode to flex up and down with the spring set-up on the locomotive for uneven track.
This is a view of the drivers on the left side. Both rear drivers AND front drivers have thinner counterweights because the pin is shorter. It only has the side side rod weight to compensate for.
My Dad and his partner owned a forging die shop in El Monte, CA and we had a pattern shop associated with the business. One of my friends was building a 1.6" scale GS-4 Daylight northern. He needed the drivers for that model and we contracted the work by building the wood patterns and casting the drivers for that engine. Those drivers were boxpok drivers, no spokes. We used actual Lima Locomotive Co. prints to produce EXACT scale drivers as used on #4449. All of the counterweights on those drivers were a different size AND shape. The counterweight on the main driver was huge having to balance almost 5000 pounds per side for one side rod and the main rod and the roller bearings in the rods! Just for kicks, take a look at a close-up of the drivers, side rods and main rods on that particular engine. And this technology was circa 1941! 80 inch diameter drivers and a few tons of rods, moving at 90 to 100 mph! Southern Pacific took pride in setting a glass of wine in the diner and NEVER spilling a drop during the entire 420 mile to San Francisco-Los Angels runs and back again.
Hope this helps.
