Vincent D’Agostino said:
I just need to stick with electric or battery powered trains…
I put the motor assembly back in, set all the wheels / drive rods & gears so they all operate properly… then the frustration started.
Keep in mind, this engine did fire up previously…
Filled the oil tank, filled the water tank (took out 30cc) took the engine outside to fill the gas and that’s where the fun ended.
The quick fill adapter that attaches to the fuel can no longer stops the fuel from coming out, it just sprays all over the place. Ron can attest to this fitting not working correctly when I was at his house as the gas kept leaking out then also… but now it just sprays out from the tip and everywhere…
The adapter for the can has a Oring and that should be lubricated with a drop of oil. Also a drop on the top of the adapter before you screw on the 3" adapter. There is a plunger and a Oring seal, if that’s dry it will leak, lubricate and depress the plunger from the top.
Still managed to get the tank filled so next was the attempt at firing it up.
Turned the oil on slightly and turned the gas on… I could hear gas flowing so I put a flame near the stack, heard the pop and figured I was going to be good to go…
The oil valve should not be closed, its set to a point usually open one turn to start and adjust as you notice the oil consumption. No less then 1/2 turn open even as that closes the supply total. 3/4 turn open is somewhat average once the loco it run in.
Well, about 15 seconds and there was no sound of the engine still being fired… shut the gas valve off, made sure there really was gas in the fuel tank (it seemed to be full), turned the gas valve back on and could only slightly hear gas flowing…
When you first fill the loco, you need to bleed off the liquid in the tank when full, so you open the valve and no not light, listen to the gas hissing and spitting, once its a smooth hiss then its just vapor. Close the valve and blow down the stack to clear the gas. Reopen and light.
Tried lighting it again and nothing…
Shut the gas valve off again and this time even with the gas valve off I could still hear gas seeping out from some where…
Checked the fuel filler on top of the tank and that was tight, still seeping gas from somewhere and not sure from where.
Check the valve itself, there is a packing nut and also the valve wheel can loosen on the stem if overturned. Also check your 2 nuts for the gas pipe.
So before I just smashed it with a hammer, I emptied the gas tank, emptied the water from the boiler and put it on a shelf where it will most likely remain.
I just don’t have the patience for this stuff, I get stressed way to easily.
Don’t use Loctite on the motor parts, there is a Teflon packing in there, if the nut is loose when you finger tighten and snug up with a wrench maybe 1/4 turn you need more packing, unscrew the nut and slide back a small string of Teflon tape twisted into a string then wrap around the shaft 2-3 times and re install the nut.
Live steam had never been a simple set it on the track and forget it hobby. It takes patience and time to tweak and set things and constant monitoring when running. Its a hands on.
BTW - If I don’t get a call if you run into a problem or trouble I don’t know you are having any issues.
