Lubriplate Plastic Compatible Lube - Lg. sizes
Having lubed locos at Palm Desert’s Living Desert giant outdoor railway, access to plastic compatible gear oils and greases in bulk would be a big cost savings. Lubriplate offers “SPO” lubes and “FML” lubes both high quality and designed to operate on plastic and plastic derivitive gears and axles. They come in 7lb. cans, 2 lb. plastic bottles, and larger sizes.
The tech person at Lubriplate’s hdqtrs., offered that SPO-255 oil and FML-2 grease would be excellent for our applications. Both are used in food processing plants and are absolutely plastic compatible.
Check the Lubriplate website for state-specific sources and the over-all descriptions.
Phone: 973-589-9150 office in Newark, NJ 07105 – main executive office.
1-800-347-5343 for technical advice – very helpful and friendly.
Wendell
Thanks for that, Wendell. Lubriplate has a distributor in Perth, and I will check them out.
Dave
You are welcome.
Please give us the prices you paid and sizes you chose.
Thanks,
Wendell
Wendell, do they have a UK outlet?
Thanks for that.
Cheers
Rod
Rod and others:
The Lubriplate website that lists the distributors: Lubriplate.com/Products/Distribtorsmap.htm
Yes, one in London:
Phone and Fax: 44 0 20 8961 7292
The site lists Austrialia, Japan, London, India etc.
The website will also take you to their products.
Wendell
More Lubriplate information:
To find a distributor –
www.lubriplate.com/locator/index.asp?
I found 20 within a drive of 4 miles to 25 miles from our home.
As to the content of the plastic compatible oil and grease:
SPO-255 (one of the SPO series) oil – a mineral oil base product.
FML-2 (one of the FML series) grease – a mineral oil/soap-based product.
Both the above are used in the food industry under high heat conditions for bearings, chains, etc.
This information came from a call to Lupriplate’s technical division. The two technical reps indicated both the above would work well with outdoor large scale loco motors and wheel axles.
Wendell
