Lubrication
What is an easy way to inject oil into cylinders whilst air testing ?
Mike M
Good question. I hope you get an answer. This problem may be the reason why it’s usually suggested to air test only at low pressure and the resulting low RPMs.
I air pressurize via the water fill. If I could get in on the stem side of the circuit I would think about injecting a wee bit of pneumatic tool oil, but I would not want that in my water boiler.
Mike M
Uh, you can’t unless you are REALLY quick with a spanner.
Most of us take off the cylinder end caps, oil copiously all around with your choice - 3-in-1 is good - and then put the caps back on.
Steam oil can’t be used as it needs to emulsify in order to function.
Roundhouse Engineering run their factory-built locos on air for eight hours, BTW.
When you are hyppa, then you clean the whole thing down - REALLY clean - and lightly oil up with steam oil to keep it oily.
tac
www.ovgrs.org
I like the answers so far , but Tac has puzzled me slightly -----I am known to be thick as two short planks----I thought emulsifying resulted from vigorous mixing . I took your comment to mean that heating was required .
I may tee an oiler into the circuit , perhaps the air will blow enough in .
Keep the ideas coming , I can’t be the only one to wonder about this .
Mike M
Mike, the steam oil needs high temperature and pressure to break down the tallow content into a working lubricant, as I’m certain sure you already know.
If you a are handy enough to ‘tee an oiler into the circuit’ then I’m sure you’ll think of a way to heat it up to a reasonable working temperature - the pressure, on the other paw, is something different.
However, I just called up Roundhouse, and Hari there tells me that when running-in on air they simply oil copiously and every now and then dollop some oil in via the valve chest covers.
If it’s good enough for them…
tac
www.ovgrs.org
Thanks for that , Tac . I didn’t know about the breakdown by heat and what it produces . So I have learned something today .
As for the Roundhouse experience , that sounds OK to me .
thanks again ,
Mike
Mike Morgan said:
Thanks for that , Tac . I didn't know about the breakdown by heat and what it produces . So I have learned something today . As for the Roundhouse experience , that sounds OK to me . thanks again , Mike
De nada, Mijneer.
Tschuess!!
tac
tac
www.ovgrs.org
[/I have set up my Airline with a Lubricator inline, I place this in a can of boiling water and fill the lubricator right too the top and keep topping this up as It do`se
not expell the oil as well as when Steam is in the line!.
Works for me!,
Stingy John./]
