In a previous posting, the lack of lubrication in brand-new locos was discussed.
While repetitive to a previous posting I made, I offer again the success from using Mobil 1 motor oil and Mobil 1 grease on plastic parts , e.g. LGB/Aristo/Bachman/USA loco gears, wheel journals, etc.
The heaviest oil I can get here in Southern Calif., is Mobil 1 in 10/30 weight. I works fine.
The grease is simply labeled Mobil 1
The MAIN point is these products are plastic compatible because they are synthetic. Other brands of synthetic oil and grease would certainly fit this criteria.
I have lubed hundreds of locos and wheel journals at the Living Desert gigantic outdoor “G” railroad display. The MOBIL 1 products work fine – and in particular on any NEW loco that comes in. All get lubrication and need it.
Your experience?
Wendell
