Boomer,
I’ll add that when I cast I use the Allumilite regular as well. What I found out is that if you invest in some smaller bottles (say those 32 oz bottles from Micro-Mark) to pour the two parts into (seperately) and leave the 2 gallon jugs sealed well (some people have sprayed nitrogen? inside to pull the moisture out) the resin lasts a lot longer.
For the RTV I’ve used both the stuff from Micro-Mark, and the stuff from Tap Plastics. Both seem to work fine.
I will add that a really handy tool to add to the casting collection is a paint pot. It’s not required, but if you have a paint pot, you can cast under pressure, thus reducing and eliminating the air bubbles. A paint pot can be converted to a pressure pot with a few simple caps, and a valve. The quality and consistency of my casting improved quite a bit when I used a paint pot.
Craig
