I think what Pete is asking is: "Is there a system that I just hook the wires to the LEDs instead of using resistors or Current Limiting (CL get it, CL2) integrated circuits?
The answer is yes, sort of. I have seen power supplies that supposedly connect to LEDs at a fixed voltage that sort of work, but they cannot work well in a situation where there’s different length of wire to the LEDs and also cannot run the LEDs at their optimum power.
This all gets back to you need to control the CURRENT to an LED as opposed to the voltage.
The Malibu systems have a sort of controlled voltage and work with incandescent lamps. If you add more lamps, the voltage goes down and they all get dimmer. No danger, just poor performance.
So suppose you want to have a common power supply for LEDs… you would have to have it control the CURRENT to run a LED, say 20 milliamps.
Now you want to add another LED, oops, you need 40 milliamps (as long as they reasonably “share” the current, another gotcha). So now you need a switch on the power unit to set the current.
So this is an issue, by the time you have a programmable power supply, you could have simply put a resistor or CL2 on each LED and be done with it.
If you look at the replacement LED lights for outdoor Malibu systems, EACH LED unit has it’s own current regulation system built inside.
Pete Lassen said:
Does anyone make a commercial made unit to take the “Malibu” power and convert it to where it will run LED building lights? After reading all 3 pages of this it is really clear what I DO NOT know. Maybe with some time,and some video or pictures I can get it but for now I can hope that someone will make something for this task. “Malibu” power seems to be an easy way to go , with direct bury wire and I want LED lighting for less electrical use it provides, and it seem like to me anyway the best way to procede.
