So we started down this rabbit hole in my MIK thread. Before it goes too far off the rails I decided to ask this here and see if anyone has ideas.
I have a hard time getting reliable pours when I cast white metal into rubber molds. I have in the past, a long time ago in Jr High School, made a ring using the lost wax method of casting. I like this idea very much as it makes a lot more sense to use inertia to throw metal into the mold and displace the air. I am thinking this would give me much better results if I get the equipment.
As I started googling I came up with a couple ideas that I am wondering about. Lost wax casting takes a wax master and you pour some sort of stuff like plaster around it in a metal cylinder. Once that dries you put it in a kiln and burn out the wax leaving the negative in the mold. You put that mold, metal cylinder and all, into a centrifuge and you pour in your molten metal and let fly. The metal is forced by inertia into the negative space. You then break the stuff out of the metal cylinder and you are left with your metal casting.
So my original thought was to see if their was a resin for 3D printers that could be used to make the “wax” masters and then pour the plaster stuff around it, burn it out, and then cast it just like you would lost wax. While this would be fine, resin is a lot more expensive than wax. This got me thinking of the evolution a bit more.
Dave T uses a high temp silicon rubber for his casting. which means he can use a mold over and over to cast white metal parts. I am thinking that a hybrid process could be done. Make a silicon rubber mold that is made to fit inside the casting cylinder and then it would, I think, be able to be cast, removed from the cylinder, parts removed, and then it could be used again.
If this were reasonable, then you would only have to make the 3D printed master (or any other master such as an existing part) one time, make the mold with it, and you are done. Just like in any other casting you would have a reusable mold. It there any folly in my thinking?
Yet another idea if that wouldn’t work well, would be to print the parts in resin and cast them into a silicone mold. Then instead of casting the metal into it, a person could cast wax to make the masters for lost wax casting. You would making a mold to mold the wax pieces instead of the metal pieces. Then the process would be the exact same as lost wax casting. My thought here is that wax has a very low melting point, enough so that the molds could easily be kept above the melting point of the wax and then if necessary a vacuum could be applied to even further pull the air out of the mold and fill the negative space with wax.
