Ted Doskaris said:
Nicolas,
- Longest trains on outdoor layout without experiencing “string-lining” vary as to car type mix, but generally range from 35 to 40 cars max.
- All cars have metal wheels.
- Locos do not have traction tires.
- Longest train ever run on underhouse portion of layout was about 60 cars, mostly consisting of Aristo 40 foot long box cars.
- Locos pulling train to outdoor layout typically comprise minimum of 3 but up to 6.
- Outdoor layout tightest curves are 10 foot diameter at viaduct area, but most are 16 to 20 foot dia.
- Underhouse layout curves include 10 foot diameter except for some rail yard access is 8 foot dia.
- The few “S” bends used are separated with a straight track section between their diverging opposite paths.
- Grades on lower outdoor area double helix average about 2.2 percent with steepest portion at 3 percent section on a 14 foot diameter curve. Grades on upper area are 2.2 to 2.5 percent.
- Underhouse portion of layout is level, suspended from rafters by threaded rod.
- Locos and cars (400+) have body mount Kadees “G” centerset type couplers - except USAT SD70s having medium upward offsets (Presently working on replacing these with centersets).
- Outdoor track is all Aristo-Craft stainless steel connected with Split Jaw brand stainless steel clamps.
- Underhouse portion of layout is Aristo brass track.
- Turnouts include Aristo #6, #6 Wye, Wide Radius having 10 foot dia. diverging path, TrainLi R7 plated nickel silver.
- Track power via Aristo Revolution 15 amp base station with multiple feed 10 AWG wires to outdoor layout.
-Ted
Its interesting that you are able to run longer runs under the house even though it has tighter curves then what you have outside.
