I take my Modular RR to about 5or 6 shows a year. I have all along carried my locomotives in their original boxes. So on a 3 Truck shay I am always unplugging the wires between the tender and the locomotive. Well I have had one of the wire pull loose. I can get it to work but Its a pain.
So I am making a box so I can leave these all hooked up. I have been thinking about this for a while. One of the other things the box must be is less than 10.25" tall so it will fit in my trailer shelves.
So Here goes. I bought cabinet grade 1/2" plywood. The Shay is about 4.5" wide. So I am making this box 5.5" wide inside dimension and total height of the box 10"
I cut grooves in the base so the wheels of any locomotive or car will roll in just like track. Then I went to the 4" belt sander and sanded one bottom end to an angle. trying to get the angle so a locomotive will roll in easily. The I relieved the wood on the bottom so that it would fit between the rails . It actually works pretty well. Once the base was done I then installed the sides and one end to the box.
Now I have to finish the box up…Stay tuned…
