All I can tell you is Aristo uses the red stuff on the taper on the axle to the driver AND on the locking screw. Many people have broken the screw off or rounded the head with the driver.
I recommended stepping down to blue, and some people went crazy.
Also, many people slather the stuff on, you only need it on a few threads. Several people have reported the locking screw and washer saturated with red loctite.
Of course there are people that use the red stuff and the screw still comes loose. Upon investigation, many of these people did not clean the screw and the threaded hole, so I suspect oil or grease in there.
I have used both over the years on all kinds of stuff, mostly automotive. The strength of the red stuff scares the heck out of me. Several people have reported success by heating their screwdriver with a torch, or applying a soldering iron to the screw head.
I think blue is enough. A little bit of blue.
Regards, Greg
p.s. 271 is for up to 1", there is no mimimum bolt size, the example torque specs start at 3/8", see page 2 of the technical data sheet. The web site states “up to 1 inch”.
p.p.s I was interested to see that both blue and red were listed as permanent, thought blue was supposed to be removeable… looks like purple would be worth a try for our tiny screws.
