I store my live steam Shay in it’s shipping carrier. I installed rail in the carrier but it’s always been difficult to unload. This picture shows a short section of track being used to connect it to my fold-up bridge. That worked, but the loco is facing the wrong way for start-up servicing.
I played around with with a PVC ramp, but was having problems transitioning from the plastic ramp to rail, so I decided it made more sense to make the ramp from rail.
I started with two 1 foot LGB rails and ground a shallow angle at one end. Aristo ties were epoxied on to hold the gauge at the top and a brass gauge bar soldered on just before the taper. I also soldered on some ears on the inside of the taper to hold the ramp in place. Here it is in test mode…
This is just over a 10% grade…
Notice that the joiners have been bent down to allow the tradition to level track in the carrier.
With the railroad covered in deep snow drifts the next chance I’ll get to run the Shay will be next weekend in Scranton where the ramp will get it’s first live test.
