The second issue is that the two axles on the rear truck have too much play in them. So much that they disengage from the bezel gear on the drive shaft.
Here is where they are dissengaging:
Here is a photo of the bracket holding the axle. There is a small bearing (a solid block) that the axle nests in and it is press-fit into the bracket. It appears to be brass. In this photo you can see just a bit of it protruding from the bracket:
This bearing slowly shifts outward creating more travel for the axle. I can push it back into tolerance by using a jewelerâs screwdriver and pushing thru the small holes on the outside of the truck:
Unfortunately, it will only slip back out.
Has anyone ever worked with this assembly before? Any suggestions how to get it to stay in tolerance?
Thanks,
Joe
