I recently purchased a used live steam three cylinder shay. After testing, I 've found two issues. I was hoping someone could advise me.
First issue: The water check valve assembly to the boiler is clogged. The hand pump from the tender delivers water (I disconnected it from the assembly and it flowed well). Can the assembly be removed and cleaned? If so, any suggestions on how to clean? Also, the grommet appears to have a slow leak. Where can I find a replacement? Finally, do you recommend using a thread sealant? If so, what brand and type?
Here is the assembly:
Thanks for your help.
Joe
