Shawn-
Many thanks.
You have given a review that is helpful. I am considering another try at steam. My Ruby finally got the therapy with the excentrics and it does work —however, the slightest grade means stalling. So I run it only on a separate circle of track on the patio. This is only to see the novelty of live steam – which tires within ten minutes. To run it on the garden layout, with 2% grades, is a series of short runs between the grade sections, then picking it up and moving to another flat section. Obviously, this is tedious.
You are acccurate on the few Aristo steamer reviews. If I am understanding correctly, the radio control unit actually operates a throttle servo so grades can be met. Am I correct here? This feature alone enables use on most of our garden railroads. I’d appreciate your take on the use of the RC feature and how you do or do not handle any grades on your own layout. I may be getting one of these locos if so useable.
Thanks,
Wendell
