Hi guys:
what is the Bachmann order number for the old 1:22.5 version of the Porter ?
I am interested in bashing a Little Hauler into a Disneyland Ward Kimball 2-4-4T style of loco.
I just want the look of the loco. Exact replica is not the objective.
The Bachmann boiler appears to be a larger diameter than the Ward Kimball which is just fine with me.
The cab is correct.
The previous MIDWEST Quarry & Mining Co. Porter model had the smoke box positioned correctly.
The Little Hauler smokebox has been pulled aft, why did Lee Riley do this when a new mold was required to be produced for the Little Hauler boiler anyhow?
Why mess up the location of the smoke stack?
Photos on gscalecentral show the axle gear to be not metal.
I think the Little Hauler loco drive is intended to pull the two short passenger cars from the train set so I guess the drive is plenty strong for the intended purpose.
Of course, once adult hobbyists start adding weight to the model and hauling long consists … who knows if the drive will stand up.
I guess the solution is to remove the stack base, wrap the smokebox and then remount the stack at the correct location with an oil box headlamp.
I just do not understand why such a major design error occured.
Norman
