Hi Bob!
Would it be possible when adding a link in a post to have them open in a new window?
I will use this as an example:
The 2-wire connector set is available from All Electronics under catalog number CON-240.
I hope you can read the source code.
Hi Bob!
Paul the link opened in a new window for me. I know in IE you have to set it to do that, and my version of IE would “forget” that setting from time to time. I am using Firefox now, and that setting is staying just the way I want it too.
If you are using IE, you can make it open in a new window by right clicking the link, and then select “open in new window” from the pop up menu.
Paul,
You set that up in your internet options on the 'puter.
