Most of my locos are plastic and I can leave them on the layouts - seldom ever having to lift them. There are a few metal locos from AML K4 & USAT Hudson to MTH & USAT Big Boys that (because they are metal and could rust) I cannot leave them on the layouts and I hardly ever run them because I am concerned about damaging them by dropping them when I might carry them from the house down to the outside layout.
Years ago I thought I had the problem solved when I built a transporter case out of 1" x 4"s but today that case is too heavy when added to the weight of the locos. The AML K4 came with a lightweight metal case but the loco has to be lifted up and set down inside the case due to the 4 rigid sides. A weak grip or weak wrist and the loco could easily be dropped. By the same token a weak knee could cause a problem carrying a heavy loco while going up and down the stairs to the outside layout.
Like many others I got active in this hobby about 25 years ago when strength and agility were not something I gave any thought to. Now, like many others, I am now approaching (or past) 70 and strength and agility have become a major concern.
My question is to others who have similar problems carrying their locos to and from heated and cooled storage to their layouts.
How do you transport your heavy locos to and from your layouts - especially if you have to carry them up and down from one level to another?
For that matter, do you have a special way of picking up and setting your heavy locos down without damaging their fragile mechanisms?
Thanks,
Jerry
