My indoor loop/yards now include 2 lift up/folding bridges where the main crosses an aisle. I have implemented rules and procedures to prevent a train from rolling into the abyss - When the bridge is opened, a Blue Flag (Ric Golding’s Aristo hex tool idea) is to be placed on the track. I drilled a hole through a tie and the roadbed to hold the flag secure in the center of the tie. In tests the flag lines up with the coupler and will stop a slow moving train. The stop is abrupt and not great for the equipment, but better than rolling off the bench.
Too bad I can’t follow my own rules.
Last night I was doing some switching. I was backing a short train around the balloon track with the bridge out of my sight line. All of a sudden I heard an unusually loud bump where there should have been a click from the bridge joint. I hit the emergency stop in time to keep the train on the track, but the caboose and brakeman were lost to into the abyss.
4 Foot down to bare concrete. Sounded bad. Looked better; the caboose was still all in one piece. The wreck crew recovered the caboose but still hasn’t located the body of the brakeman. Back at the shop, a full inspection noted surprisingly little damage. One hand rail popped off, the roof joint separated from the body a little and the body was unsnapped from the frame at one end. There were minor scars on two corners of the roof and the coupler tang was bent.
Repairs took all of about 15 minutes leaving only the minor scars on the roof. It appears that the truck mounted coupler absorbed the majority of the blow when the coupler mount buckled. But with a little gentle persuasion it was moved back to near normal.
I learned 3 things. 1 - Bachmann cars are surprisingly sturdy. 2 - Always check the bridge before crossing. 3 - Always follow your own rules.
Now where the heck is that brakeman and why didn’t he pull the emergency cord when he saw the bridge was up? Dang plastic people, always sleeping.
JR
Color it blue if you like.
