I’ve had good success with Li-Ion packs in my Porter. I have an 11.1V 2200mAh pack left over from that project and a spare RailBoss ESC and a Spektrum Rx. I’d like to put together a trail car for my diesel locos. I know that the single 11.1V pack won’t do it so here is the question…
- Add a 7.4V 2200mAh pack wired in series to get 18.5V (locos run fine on an 18V drill battery) and charge separately at different voltages (my charger does not support 18.5V packs)
- OR
- Add a second 11.1V 2200mAh pack wired in series to get 22.2V and simplified charging (charge in parallel as 11.1V)
I’m basically cheap and option #1 saves $4.50. I’m thinking option #2 saves a lot of aggravation and charge time down the road. It also leaves some pretty good voltage overhead in the pack.
OK, you convinced me. Option #2 it is.
