LGB Speeder - Battery Powered
When I disassembled the motor block to remove the sliders, i noticed LGB has made 2 significant design changes. The first being a much more robust contact strip between the axles and the sliders. The second change is the addition of separate bearing journals similar to USAT except theirs are made of some type of plastic. I’m assuming they would be part of the replacement wheel assembly and solves the problem of worn motor blocks.
Sorry, didn’t work with text
