I just completed programming some CVs on my newly purchased LGB 22892 DC/DCC Sound Sumpter Valley Articulated Mallet. Historically, the Sumpter Valley Railroad bought both the #50 and #51 mallets from the Uintah Railway in late 1930s, reconfigured them by removing the loco water tanks, and then operated them with tenders attached. This LGB Sumpter Valley model uses the basic design of their LGB Uintah loco, both produced by the original LGB (Ernst Paul Lehmann Patentwerk) in the early 2000 timeframe with an onboard DCC decoder technology built into the main circuit board by Massoth - Germany. Today I was frustrated trying to program three CVs (CVs 1, 52, and 54) when I received the “check mark” on my Massoth Navigator Wireless Controller which means the CV was successfully changed…but the loco didn’t “jump” back and forth as normal when I pushed the OK button. So I Read the CV, it still had the original CV value…didn’t work. I tried it a second time, same result. Frustration!
So, then I remembered the process recommended by Soundtraxx for their Tsunami2 decoders…de-power and re-power the locomotive/decoder after pushing the OK button. So, I unplugged my Piko Central Station that powers my programming track, and re-plugged it. Tried programming the errant CVs again, and bingo, it worked! So, if you have a problem trying to program one of these older LGB locos with the onboard DCC decoders designed into the main circuit board, de-power and re-power the loco/decoder, and try again. This is especially true if using a non-Massoth DCC system. In fact, I had problems using my Massoth DCC system two years ago trying to program CVs with Soundtraxx Tsunami2 sound decoders until I watched one of their help videos and saw the techie raise one side up of the loco he was programming…he did it immediately after each CV setting. I tried it and bingo, it worked!
Tom
