Hi Pete - Thanks for a very generous offer. I need a 6-pin tender board. I see the green tender you have is from an LGB 2018D Mogul and I know that they have a 3-pin board. I can’t see what board the black tender has in it, not sure even if it’s an LGB tender. But if it is LGB and does have a 6-pin board in it, I could use it. On Mogul tenders, there are three screws under the tender that hold the board in place. I only need the board so if there are any wires/cables soldered to, I don’t need them. You could just cut the wires off the board if there are any wires soldered onto it.
If it is a 6-pin board, do you also have any LGB locomotive six-wire cables with plug that are used to connect to an LGB tender? If you have any that you don’t need, I can certainly use those too.
You must be running battery power and don’t need or use LGB loco - tender cable connections?
Tom
