Has anyone ever doubleheaded an LGB Analog & Digital Mogul? First, I have an Analog system, & here is what happened…
I ran the digital engine in the front as the analog engine has the plow & the coupler in the front. When I did this, the analog engine rode
up the rear coupler, {I use euro couplers}, of the digital mogul. Since both engines have the same motor, is the answer the weight
of the analog engine vs the weight of the digital engine. I haven’t weighed the engines, however the analog mogul seems heavier when
you lift it? I have run two analog moguls together before & both pulled the same, & seemed to be in sync.
Thanks,
Ed Engle
