LGB Mikado 25872 hall sensor board question
Hello,
I’m converting a LGB Mikado to Railpro. I found the hall sensor board. It has two hall sensor chips up at the top and six pins out at the bottom.
Pic here
As far as I can tell, the pinout for the chip itself is ground, signal, positive.
I think - but am not certain - that the pinout for the board is, counting from left to right:
1 - signal chip 1
2 - ground
3 - signal chip 2
4 - ground (connected to pin 2)
5 - dunno
6 - power
Can anybody shed some light on this? I’m nervous about getting power and ground backwards and blowing up the board.
Is this a standard LGB part or is it Mikado-only?
Thanks!
Hi Algae, I’m sorry I can’t answer your question but welcome aboard. And keep posting!
what is a hall sensor?
i’m with Cliff in that.
but be welcome.
(sure enough there will be enough counsel shortly by the sparky corps)
Korm,
A hall sensor is basically a square wave pattern on off switch .
by now you should know, that i understand the explication not.
(hereabouts we still use a hammer to turn off the light)
i just tried to be friendly to the new poster.
ps: do you know, where to get a reserve key for my clockwork loco?
