I have an LGB Forney that only picks up power from the rear truck. The drivers and skates have no power connection to the motor (verified by multi-meter).
In the picture below you can see the long pins (111 and 141) connect all the driver brushes and skates but there is no connection to the motor leads (pins 112)
Per the exploded parts diagram nothing appears to be missing…
Pins 112 (2x) contact the motor +/- tabs (verified as I tore down the motor block).
Pins 111 and 141 connect the brushes and skates but nothing appears to connect either of these to pins 112.
The diagram is for a sound equipped version I do not have. The four wires leading to the power-block are all black.
http://www.lgbworld.com/service_manuals/20252-1.PDF
I am thinking of soldering a jumper between these pins (one on each side connecting pins 111 and 141 to their closest pin 112). I will likely do this at the connector.
So what is missing here? My Mikado has two brass strips that make this connection but none show up in the parts diagram for the Forney.
