LGB F7A replacement wheels?
So I picked up an LGB F7 A/B set on ebay and while the bodies are like new/perfect it is apparent there has been some significant run-time. I tore down the motor blocks, cleaned out all the old grease and re-lubed the gears. I also replaced the skates and all brushes. I’d like to replace the wheels too, though the axle gears are perfect I don’t like the wear on the inside of the tyre. All my searching has come up nadda…Any one know a source for these?
Thanks!
Mark,
the wheels are a stock generic ‘blank’ wheel fitted to most non-steam production from LGB . They were also fitted to the dummy motor blocks on the LGB LCE trains (people list these on eBay when they repower the dummy block). Try Alex tillman at Train-Li USA. If he does not have them then his source in Germany will have.
